After being away for two weeks at Boeing in Seattle taking the B-777 training I continued on the left wing fuel tank preparation. First I contersunk the tank aft bulkhead rivet holes, see image 1. Then I turned to the tank inboard bulkhead. I installed the access panel retaining ring and anchor nuts, the fuel pickup tube, fuel pickup tube anti-rotation bracket, fuel tank vent line line fitting and BNC connector (for the fuel quantity indicating system). Then I made the vent line and installed the snap bushings in the ribs that the vent line passes through, see image 2. Finally I installed the mounting hardware on the fuel quantity indication system capacitance plates, see image 3.
